I haven't started wiring yet... just figuring out what all these cut wires are on the engine harness. It should not be difficult to wire it in with the fuse boxes in parallel from the battery. obd0 to obd2 is pretty different than what most people do, or to the swap you are referring. If you have a link to where someone has done this "simply" I'd like to see it. Not kidding, I would. I'm an electrician by trade, I like wiring to be tidy.
