212 degrees is the boiling point (unless you are at high altitudes, which is even lower). Even with radiator coolant, it's best to keep it below that temperature.
Personally, I wouldn't attempt a radiator/grill block without a temp gauge (nor would I own a car that didn't have a temp gauge.) The idiot light comes on only after the car is overheated. IMHO, that's too little, too late.
I notice he said there is a coolant temp readout. He could work with that. Much better than idiot lights or gauges that have no markings on them (which are still better than nothing).
