Old 12-09-2009, 07:06 AM   #11 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
Originally Posted by Old Tele man View Post
...tire "hysteresis" is a function of rubber flexing upon contact with the road, then compressing under weight, then un-flexing upon release from the road.
...that's *why* an older, well worn tire has a lower rr value than does an identical brand new tire.
Hysteresis is the amount of heat generated for a unit volume of rubber doing a unit of flexing. Think of it as internal friction.
And since there is less rubber in a worn tire, that's why worn tires have lower RR than new tires - everything else being equal.
The Following User Says Thank You to CapriRacer For This Useful Post:
rgathright (12-09-2009)
