Old 12-09-2009, 02:02 PM   #2724 (permalink)
jackbauer
jackbauer's Avatar
ah ok my bad Don't have a problem with the jailbreak! I was never big on buying a product then being told what i can or can't do with it! Anyway back on message I built up another control board using bits i had myself and could source locally and seems to be ok with initial tests. Sadly the only part i could not source was the common mode input choke so i've linked it out for now. For anyone interested here is a list of stock numbers for some of the parts i used from Radionics (Welcome to Radionics On-line)
197-4069 1 €7.71 €7.71 28 way turned pin DIL socket,0.3in pitch
365-4155 1 €1.82 €1.82 NHG min Al electrolytic cap,470uF 25V
449-1006 1 €0.92 €0.92 FC radial elec cap,10uF 25V
538-1483 1 €0.93 €0.93 Radial X7R ceramic cap,22nF 100V 5mm
538-1916 1 €2.14 €2.14 T350 radial tantalum capacitor,16V,4.7uF
642-4547 1 €4.44 €4.44 HIN202CPZ
654-7628 1 €1.60 €1.60 20V Zener diode,1N5357BRLG 5W
I could not source the transorbs so substituted some 20v 5w zeners. Nasty i know
528-8536 1 €1.97 €1.97 Miniature NTC S861 thermistor,10k
661-9798 5 €0.45 €2.23 V-Ref Precision 2.5V 10mA 3-Pin TO-92
This is pin compatible with the specified device.
625-8665 3 €0.36 €1.08 Opto-isolator,2500V DIP4,TLP521-1(A,F,T)
Pin compatible.
466-7067 1 €24.15 €24.15 TEL5 DC-DC converter,9-18Vin 12V 6W
Pin compatible.
169-6012 2 €0.46 €0.92 Quad 2 i/p NAND gate, 74HC00N DIP14
661-3160 1 €2.77 €2.77 MOSFET DRVR 9A Single Lo Side Inv 8-Pin
Pin compatible.
810-239 3 €0.13 €0.39 Dual comparator,LM393P 1.3ns DIP8
522-2766 1 €0.79 €0.79 3386P top adj cermet trimmer,500R 10mm
214-0734 1 €2.43 €2.43 ROX1S metal oxide film resistor,1R0 1W
294-328 1 €1.55 €1.55 PNP transistor,2N3906 0.2A
672-0218 5 €0.38 €1.90 Crystal,16.000MHz HC49U
Hope this helps. I have not included resistors or basic caps as they are standard.
