Originally Posted by jackbauer
.... I built up another control board using bits i had myself and could source locally and seems to be ok with initial tests. Sadly the only part i could not source was the common mode input choke so i've linked it out for now. For anyone interested here is a list of stock numbers for some of the parts i used from Radionics .......
Hope this helps. I have not included resistors or basic caps as they are standard.
A probably stupid question but, why there is a vacancy in that 8 pin IC?
Is this Paul's second controller PCB version?
