Originally Posted by Christ
Of course, if a smaller, lighter, more aerodynamic car is making nearly the same HP as a much larger/heavier truck, it will make more particulate emissions because the engine won't be loaded sufficiently to be efficient, and will be burning fuel uselessly. Does that make sense?
From the perspective of BSFC it's consistent, but emissions tend to be the opposite. At least for
older diesels, particulates go up w/ load, NOx/CO goes up w/ load and speed, and HCs are roughly the same.
Seems like taking some of the power away from the car, or chaning the power curve itself to allow for more load at lower RPM, while still allowing the power to be "fun" when the operator requests it is in order?
That's pretty much what manufacturers have been moving towards for the past decade or so via drive-by-wire, variable cam phasing, eleventy billion speed automatic transmissions, cooled EGR, and so on.
