Old 12-10-2009, 01:40 AM   #6 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Example:
Also it will tell you if you are running an pulse width of 3.0ms with a A/F ratio of say 13.5 but you want a A/f ratio of 14.7 it will show what the new pulse width for the desired 14.7 A/F ratio.
Plus it gives cfm and air lbs/min on theoretical values.
Let me know if you guys have any questions.
I have to give credit to Ben Strader of EFI 101 University.
Its his math that he got over the years from all the OEM MAP based EFI systems. I just put it in a xls spreadsheet so I get the info fast for tuning purposes.
I use it all the time for figuring out different scenarios.
I also made an mpg one base that I need to do some tweaking on before I release it.
Pressure Gradient Force
The Positive Side of the Number Line
