Old 12-10-2009, 11:25 AM   #12 (permalink)
shovel
Interesting that the two derogatory posts (desertbob and mkrusz) are from their respective posters' very first & only post.
I have also used E85 quite a lot in my 2001 S10 v6 and my 1992 Ford Tempo and in two 1991 Isuzu Troopers.
All 4 cars behave(d) exactly the same on E85. Fewer miles per gallon of fuel, drastically more horsepower, and a smoother idle. And on the s10 my check engine light would come on (bank 1 lean code) because of the different stoichometry of the fuel - it no longer does this because I have had the PCM reprogrammed to allow faster sampling and a wider PWM band for the injectors, and have increased line pressure (with a tiny washer behind the FPR spring). On gasoline fuel trim stays about -6 to -9 and on E85 trim stays around +9 to +18.
You can call me fully sold on ethanol. If I could buy E85 more than 2 places in town it's the only fuel I would run. Yes I get fewer miles per gallon, but the net cost per mile is about the same and with a smoother idle and more pep I enjoy the drive more. Not to mention it does support domestic farmers, domestic waste processors (in Phoenix we have a plant that diverts trash from the dump and turns some of it into ethanol) and produces fewer pollutants if my emissions test in the S10 is any indicator.
Work From Home mod has saved more fuel than everything else put together.
