Old 12-10-2009, 12:48 PM   #12 (permalink)
DonR
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
Originally Posted by Christ View Post
If the electric water pump is ECU controlled, why would you need a t-stat at all?
I mean, the ECU could just shut off the pump and monitor temps until the pump needed to move the hot coolant.
Heater circuit. Most thermostats/housings have a bypass to allow coolant to circulate through the intake manifold, if applicable, and the heater core. Without a pump always pumping this either wouldn't happen or would circulate very slowly. I suppose a second small pump could be used for this.
Don
