If either of those is large enough, a water bed heater pad will work to heat them up quickly on cold mornings. Those things get pretty hot. Not sure how you'd mount them to the parts, though.
Maybe for the trans pan, you could replace a couple of the bolts with studs, leaving enough to hang a second pan under the first w/ the heater in it?
Just a thought... you can kick me in the shin if you don't like it.
