Old 12-12-2009, 12:42 AM   #122 (permalink)
bwilson4web
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
Originally Posted by orange4boy View Post
So the heater core and engine block share a circuit and the rad is separated from that by the tstat. I forgot about that. So the inline coolant heater can circulate (by convection) the coolant thru the block with the tstat closed. Potentially much better pre heat than a block heater especially for the cabin air.
Could there be a sweet hack here using the existing inline coolant pump and a passive inline heater to really warm the engine/heater core loop? This would be much better/cheaper than relying on the convection of the tank pump's bypass system.
I'm feeling warmer already...
Thoughts?
It would take the pump because the inlet and outlets are on top:
The plumbing is not trivial but doable.
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
The Following User Says Thank You to bwilson4web For This Useful Post:
orange4boy (12-12-2009)
