Old 12-12-2009, 02:10 PM   #5 (permalink)
MetroDriver1
Metrosexual - '90 Geo Metro
90 day: 55.67 mpg (US)
From what I have read the thing that increases your torque is advancing the cam timing so a re grind is not necessary. of course what are you going to do with the extra torque if you dont have the high gears to slow the motor down? see if you can get larger diameter tires/ wheels to change the gearing, just be sure to keep the tires narrow!
