Old 12-12-2009, 02:20 PM   #8 (permalink)
NiHaoMike
Fan efficiency is a very complex topic.
Quick Shot review 11: Thermaltake Extreme Volcano 12
Cooling fan aerodynamics can get complicated. Swept area, blade profile, static pressure, free-air flow, RPM limits for acceptable noise levels; a lot can go into the design of a modern pentametric fan. The way the equations shake out for most 80 and 92mm computer cooling fans, though, means they have seven blades. Generally speaking, fewer blades mean higher efficiency; the same goes for propellers, which is what gave rise to the counter-weighted single bladed props used by some very strange aircraft. But it's my no doubt criminally over-simplified understanding that dropping a normal cooling fan design to, say, three blades, would mean you'd have to run the blades so fast to get the same air flow as a less efficient 7-blade fan that the resultant device, while efficient, would make too much noise and/or wear out too fast.
I actually have a small inverter drive fan with 3 blades, probably originally designed for computer cooling. I use it as a desk fan during the summer since it is very efficient.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
