winkosmosis -
Read the last sentence of the first part you bolded in that quote.
" At 62 mph it's only 1/16th psi which is unlikely to generate much force on all but the craziest of aero packages. "
That's 1 lb per 16 sq inches of added contact surface (in plan view) of added downforce. The only real advantage is pushing less air under the car, more out and around/up and over it, into less turbulent areas, so less energy is being used to compress air between the road and the car, and there is less of a venturi effect.
That's cool and all, but you could lower your stagnation point without a lip/chin spoiler or splitter, just by changing the shape of the bumper.
