Originally Posted by Winfield1990
......1000x more conductive seems to break some physics laws.
So if thats the case, what do you think of superconductors?
Because I assume that this theory is based on the 20degree celsius scale of measurement and compared to copper while also at 20 degrees
Most reported results do not correspond to 20 deg C, though that value maybe in the data, there is no requirement that a value be given at that temp.
It does appear that the conductivity of carbon nanotubes varies greatly with temperature, far more than Cu conductivities.
Once again understanding the difference between conductance vs conductivity.
