Hi,
Originally Posted by basslover911
Or a "ring of heat" ... simply a heated filament to melt the snow when a sensor "sees" that there is no light going through (a la iphone if you know what i mean) ... so when there is no light coming through that means its covered with ice/snow... and the heater turns on ... simple
Yes, a thermistor could turn on a backup incandescent light bulb (an infrared heater that happens to put out a little visible light!) behind the LED array to warm the whole thing up.
Because folks, it's not like the incandescent was perfect! They burn out, they use a lot of power -- and the unintended consequences of using too much power
in total is what we are seeing today!
Any design solution is a mix of compromises.
