Originally Posted by vpoppv
Ok MetroMPG and TheSGC, I used this beautiful 64 degree day to insulate the batteries as you suggested- the high for Tuesday is supposed to be 30, so it's just in time.
I also had enough foam left to insulate my hot water heater  .....
That is great! You had some great weather there. I had 30F and work on my insulation too. I had to seal it up because I removed it a few weeks ago and when I put it back together I didn't align it right. So now it's pretty tight and loaded up with duct tape.
