Old 12-14-2009, 03:53 AM   #62 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
You made the same suggestion across some 5 threads in 13 posts. Not a good idea.
Beside that, you've been presented with all the evidence that there is to give that your "suggestion", which at this point, we can only assume has an ulterior motive, is completely biased toward what you believe, and not based at all in reality or fact, and you still make the claims without any real evidence to back it up, let alone without having done any research on your own to even appear to have half a clue what you're suggesting.
Please - take a break before you dig the hole too deep, and do some reading around here. Get a feel for the type of information that holds weight on this site, and make your next several posts "up to snuff".
27 posts in 1 day about the same subject across several threads just isn't necessary, nor is it anything less than annoying.
To keep this light, (I'm sure everyone on here normally already knows) I'm not being a dick here, but making a suggestion that if you intend to get anywhere on this board, you step away from the keyboard and begin to understand why you have two eyes, two ears, and only one mouth. (See and hear more than you speak...)
