Originally Posted by BamZipPow
Giving this some more thought...maybe one could use this as a platform to screw/fasten/secure the cover to...
Time to make a run to Discount Tire and see if they will give me 16 old wheel weights...
I actually thought about it some more, and I honestly don't remember if the clips will actaully stick to the rim once you've removed the lead... I actually thinmk for some reason that the back of the lead is part of the holding mechanism.
However, lead is dense enough that you could use it to retain the screw heads, as well. You'd have to clip the weights on and have an understanding shop balance the wheel so they didnt' get removed, though.
