There is also this recent thread:
http://ecomodder.com/forum/showthrea...tor-10572.html
In my attempt to retain ICE heat, the foil/foam/foil is wrapped loosely
around the front, top, and rear of the ICE. It's still there now some 2 months later.
I'm continuing to see a 2-3 MPG increase in my typical 28 mi. daily round trip
commute. This may be mostly due to ~5 degF increased coolant temps via
ScanGauge in the 185-195 degF range. I do roughly 35% highway, 65% urban
driving.
In my limited experience, when it's windy and you're at a standstill, you'll need
a tight fitting "cozy" around the ICE to keep heat from being scoured out from
the engine bay.
Still, every little bit of MPG increase helps.
