Old 12-14-2009, 07:24 PM   #12 (permalink)
aerohead
Iso
Originally Posted by 3-Wheeler View Post
Hi Aerohead,
Thanks for posting your chart about air drag versus temperature!
I'm not questioning the presented data, but simply pointing out that there must be other factors in the ISO table besides absolute temperature ratios.
For example, I work allot with air flow at work, and have to compensate for temperatures and barometric effects of the air, and the resultant mass flow rates of various flow meters we have.
Fortunately, barometric pressure is already in absolute numbers, i.e. inHg, kPa, or psi, which ever units you prefer. As the barometric pressure goes up on a given day, the air drag on our cars goes up by the same amount, just based on air density due to barometric pressure.
When working with baro readings from radio stations or TV, make sure to convert their reported number to the true barometric pressure at your specific elevation, otherwise you can be easily 2% off in your calculated numbers.
And air temperature has the same affect, except as the temperature goes up, and air density goes down. And we have to deal with air temperature in absolute units, rather than relative. Absolute units are typically Rankin or Kelvin, whereas relative units are Centigrade or Fahrenheit.
To get the absolute outside temperature in Rankin, just add 460°R + the relative temperature in °F, so room temperature is 460°R + 70°F = 530°R
Then if you want to know how a change in temperature affects air drag, just calculate the ratio between the temperatures to find the effect on air drag.
Such as other things in life, the ISO paper most likely has other factors that affect air drag that I don't know about or haven't considered. There is the z-factor compressibility of air, that is used when dealing with the true density of the air at pressures higher than 100 psig or so, but that factor is typically so small for our purposes here, that it does not need to be considered.
Again Aerohead, thanks for posting your info. It's a useful tool for those who are interested.
Jim.
Jim,I do not have any of ISO material.The last SAE material I bought was at a time before the international standards came to be adopted.
I did dig into my rats nest and found something which I believe dovetails into what you've brought up which generates the most accurate reflection of ambient conditions at a particular location,whereas my table is for only standard atmosphere and elevation.
My SAE J1263 which deals with coastdown testing has an air density correction which use absolute ambient temperature,either Kelvin or Rankine,and standard along with ambient baro pressure:
( Pstd )X( T ambient )
( P observed) X ( T std )
My data came from Psychrometric tables which are for 29.92" Hg and 59-Degree F
Since I'm working with US standards,standard pressure only,and using the same example at -20 F:
( 29.92 ) X ( 5/9 -20+ 459.67 )
____________________________
( 29.92 ) X ( 5/9 59 + 459.67 )
= 0.84768,then taking the reciprocal =
1.179685,or 17.9685%
For the more accurate measure you'd factor in the actual baro pressure.
So the ISO method is clearly the superior.I see another page to print up!
