Old 12-15-2009, 02:01 PM   #68 (permalink)
NeilBlanchard
The two rings that are angled on one side are so that you can "aim" the camera by clamping it in the mounting hole. In my installation, these were not used, but if the fin you got has a hole for the camera, try putting one of the angled rings on the outside and one on the inside -- and then spin them relative to each other, and you will see the range on different angles that you can achieve.
