Old 12-16-2009, 07:00 PM   #31 (permalink)
brucey
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
As far as the "Only leaving the lugnuts exposed"
I also like this idea. It makes the pan a semi permanent mod since you dont have to take it off to check the pressure or take the wheel off.
I have positive results with something similar, simply taping up the wheels:
This seemed to help, but after a few months winds started tearing the tape and I took it all off. If I had to do it again I'd either layer the tape more or find some other way to fill in the gaps. I also had a lot of problems around the valve stem, to the point that I eventually took the tape off around that part of the wheel entirely.
