So are you going to do a variable heat control so that you can fine-tune the intake temps to figure out where you get the best economy in a given situation?
This could require alot of intense testing to find the perfect temp for each situation, but it might be worth it if you could program a circuit to control the temp based on inputs from the ECU's sensors... that would be awesome!
![Thumbs up](/forum/images/smilies/grinning-smiley-003.gif)
