Originally Posted by Christ
Unfortunately, I've actually seen improperly mounted coil springs launch about 30 feet out and probably a good 30 feet in the air, finally coming to rest across two power lines, making the town not very happy with my friend.
OT note -
The voltage/amperage in service lines is enough to literally cut a spring in half if contact is made strongly enough. Consequently, the surge will probably kill one or more transformers.
That would've been a sight to see!
Just an update:
I might have a local guy with the springs I need so my deal with Ben is on hold until I hear back from potential flaker guy (most local guys from the car forums tend to flake out on buying things)
