Originally Posted by apowers
My charger is bolted to the vehical and I have a ground fault breaker to interupt
the power, just in case. It has worked a time or two when the acid made a short
to the frame. I have since isolated the batteries better.
Alvin
Alvin, you had said a few pages back, you had built one of these. I was wanting to try, but not sure what to do for the inductor. What did you
use? Thanks, Watt
