Starting the ICE
Does anyone know if any of the serial hybrids use some of the energy near the end of the battery charge to run a block heater to warm up the ICE?
I assume you need to cool the traction motors. If you use the ICE coolant system to cool those as well, it would preheat the engine for start up & help to heat the cab reducing the need for electric heating would it not?
Don
