Originally Posted by Tygen1
I've only just recently started watching the MAF, like Tuesday It seems to be right in line with the GPH readings, they seem to follow each other.
Well, that means that unless you can restrict the intake's volume while keeping the intake cold, you're not going to get an accurate result during the tests to tell if cold air is better than hot air for a given volume.
Not that your test doesn't depict real world circumstances, but I wonder what would happen if you were pulling in the same volume of air at a different temp/pressure?
