Old 12-19-2009, 03:15 PM   #216 (permalink)
jackbauer
jackbauer's Avatar
Originally Posted by watt-a-mezz View Post
Impressive collection, I would not have a clue how to hook it all up. I wanted
to ask if you could tell me how to wire up a multiple voltage charger
transformer, to run in a bonn type charger? It has 1 input and 3 tabs
for the switch, 2 E and a loop on the other side. Just want to be sure
I dont mess it up. Thanks, Watt
I guess your wanting to use the transformer as an inductor to limit the charge current? I'm guessing its a triple voltage transformer from your description. If so connect the live to the 0v tap and use the other 3 as outputs. The different number of turns will give different inductance and thus higher or lower charge currents. If you can post a pic of the transformer mabey i can give a better description. You might want to consider a sodium lamp ballast. Ready made current limiting inductor
The Following User Says Thank You to jackbauer For This Useful Post:
watt-a-mezz (12-19-2009)
