Old 12-19-2009, 10:20 PM   #38 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Originally Posted by brucey View Post
If the output voltage on those panels are 60 volts how are you going to charge a normal 12 Volt battery?
to charge a 48 volt battery pack you need to get them up to 60 volts to equalize the batteries and my parents system is 24 volts altho the panels are wired to 72 volts with a maximum power point charge controller that drops it to 24v right before the batteries so they could use smaller wire under ground, it also allowed them to get more total watts out of the array.
