12-20-2009, 12:33 AM
#141 (permalink)
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
Originally Posted by orange4boy
Great minds think alike.  I was just toying with that idea today and now I think I have the design. It's a pan heater sandwich: heat sink, gasket, hole in pan, gasket, 1/8 aluminium, heat sink grease, element, steel cover. (optional: appliance insulation, stainless cover) Two bolts through the whole assembly except the heat sink which would be blind tapped.
It sounds complicated but I think I could easily throw this together in a couple of hours, minus the stainless cover.
I can steal the pan off the old tranny. Engine oil heater could be done later.
I sure wish I had a little milling machine.
Yeah, scary.  Having the heat sink would eliminate spot overheating of the oil as long as the wattage is low enough.
I wonder if my local plastic shop sells high temperature plastic. That stuff would come in handy for these kinds of applications.
Can't wait to see what you come up with!
