Old 12-20-2009, 06:26 PM   #21 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by Tygen1 View Post
How much boost are you running at these low load crusing rpm's while lean burning? You'd think a turbo big enough to make 450hp at 30psi wouldn't do much at under 2000 rpm...Is the Turbo just helping to reduce pumping loss in these conditions?
Not much boost at my low load level cruising rpm's. But it is helping a ton as far as pumping losses. I'm running a Holset 351 diesel turbo.
Pressure Gradient Force
The Positive Side of the Number Line
