8mpg WOW what are you driving?
also you must have bad tires or something usually lower psi is worse on ice and snow. you want higher to lower your profile and penetrate the snow better. though I guess if its really icy and not snowy lower psi will increase your patch and work better like with rock crawling. Hmm might have to test that one day :-)
