Old 12-20-2009, 11:56 PM   #64 (permalink)
winkosmosis
orange4boy, higher load increases the rubbers conformity to the bumps in the surface, but there is no rule that says the friction per unit area increases linearly with downforce. Halving your contact patch doesn't necessarily increase friction per square inch by 2x, so you can end up with less total traction.
If that weren't true race cars wouldn't run wide slicks to maximize surface area.
