Old 12-20-2009, 11:59 PM   #65 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by winkosmosis View Post
orange4boy, higher load increases the rubbers conformity to the bumps in the surface, but there is no rule that says the friction per unit area increases linearly with downforce. Halving your contact patch doesn't necessarily increase friction per square inch by 2x, so you can end up with less total traction.
If that weren't true race cars wouldn't run wide slicks to maximize surface area.
Do you have, or know, the math to determine friction coefficient? What variables would need to be covered?
I imagine that most of them would fall within a very tight range when only considering street tires that are normal use types.
