Old 12-21-2009, 01:31 AM   #75 (permalink)
winkosmosis
Originally Posted by Christ View Post
This does not jive well with observed events. It might also contradict your previous quote, but I don't have time to read them thoroughly, at the moment.
I'm sure someone else will get to it, though.
It does jive with observed events. See the article on wider tires at the rear of the sports car to encourage understeer (aka safe handling).
BTW, I think to get the bigger contact patch with the wider tire you need lower tire pressure. If you ran the same lower pressure with a skinnier tire you'd have more deformation.
Edit:http://www.performancesimulations.co...on-tires-1.htm
According to those numbers, the ground pressure at a given air pressure isn't necessarily the same for two tire widths.
Yes I know it has nothing to do with this discussion between different pressures for the same tire.
