Old 12-22-2009, 11:37 PM   #2793 (permalink)
Oval_Overload
24.27 lbs per gallon Co2
Oval_Overload's Avatar
Unicorn - '12 Nissan Versa 1.8S hatch
90 day: 31.9 mpg (US)
How about the "I forgot to unhook the extension cord from the car before driving away" lockout?
Zap! implements this with a relay on the throttle. 110 VAC disconnects the throttle, and high-pedal lockout prevents any shenanigans if you were to unplug while in "drive" mode.
That is an option, but then again a relay is a mechanical part that can fail. Bones' method involves fewer mechanical parts and less 110VAC wiring.
~Jimbo
Hehehe... If one of your facial lacerations leaves a small scar, you'll have a SCarlett.
