Old 12-24-2009, 12:59 PM   #12 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by tasdrouille View Post
pgfpro,
How do you tune individual cylinders? How do you get your feedback for individual cylinders? I guess you do this on your del sol.
On TDI engines, each power stroke is sensed by the crank sensor and fuel trims for individual injectors are adjusted to compensate for variations between cylinders and injector bodies and make the engine run smoother.
On a gas engine with perfectly matched injectors and cylinders I can see how you could compute individual cylinders AF ratio from the power they generate given an equal quantity of fuel injected in each cylinder. But as soon as there are mechanical variations between cylinders, say uneven compression for example, or something that throws an injector's flow off, that all goes out the window.
I think it would be easiest for manufacturers to ensure their intake manifolds evenly distribute air between cylinders, or just go with an o2 sensor per cylinder.
Yes I'm running it through my engine management. What I found is when it goes into lean burn mode the cylinders change a lot between each other.
I'm still not to sure why but I have some theory's. So what I do is run the car on a chassis dyno and run four individual W/B O2 sensors.
Pressure Gradient Force
The Positive Side of the Number Line
