A larger gap should help with FE as you should get a better burn. The problem with large gaps is it takes more voltage to fire the plug. This starts to become more of a problem as rpm and load increase. Also as a plug gets dirty, its easier for the path to find a short to ground as the larger gap must be overcome.
