Old 12-25-2009, 06:56 PM   #5 (permalink)
user removed
Just above the 4-0000 marks there is a blue dot on the side of the vertical part of the plastic housing. On the other side on the top flat of the plastic is a white dot.
On the lower portion bright metal band there is a green stripe on the left and a white one on the right. More of a slash mark than a dot.
I can take some photos is you need them to better understand the explanation.
regards
Mech
