Old 12-26-2009, 12:58 AM   #54 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by maxc View Post
Water can speed up the overall combustion process. http://www.not2fast.com/NACA/naca-report-531.pdf
Heat reflective coatings on the pistons and head.
Very high compression with the right heat range of spark plug, very finely controlled water vapor flow, and strong long duration spark.
Thanks for the link I will read over the material.
Pressure Gradient Force
The Positive Side of the Number Line
