Old 12-26-2009, 07:47 PM   #14 (permalink)
NeilBlanchard
Yes, it is a cam driven engine, like the Revetec (that I mentioned earlier). The problem with a crankshaft engine is the maximum pressure occurs when the connecting rod in nearly straight up, and there is very little leverage that can turn the crankshaft. (A lot of force is trying to bend the crankshaft...)
With a cam driven engine, you can design the amount of leverage you have; rather than being locked in to a sinusoidal piston motion.
On the Shepard engine, is the combustion sleeve inside (and concentric with) the rotating cam sleeve? I wonder why the levers are required at all, then?
