Old 12-26-2009, 11:16 PM   #11 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
What do you use this truck for? no point is us suggesting mods that are going to make the vehicle less useful to you as a work vehicle.
You might look in to a belly pan for it as the two highest drag parts of a vehicle are the underside and the rear of it and on a truck it seems like the worst part of it is the underside, next up is the drive train with all of the gear boxes, synthetic gear oil should help here, you might also check on higher pressure heavy truck tires, they carry more weight, last longer and have lower rolling resistance but they don't fit on standard rims, however there are a few companies out there who make after market rims that bolt on to your vehicle and take these tires.
