There's the lower core support, holds the radiator/condenser if you have one
The upper core support, has the hood latch mechanism and the radiator retainer brackets.
The mid-support, which bolts between the upper and lower core supports, helps to hold the hood latch mech in place, and also has a bolt hole or two for the condenser coil and possibly power steering line, which you don't have.
That should be all, that I can think of.
