Old 12-27-2009, 06:11 PM   #516 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by SVOboy View Post
Also, should the fuel pump be constantly on? It sounds like it's just pushing fuel in a circle around the lines instead of priming and then shutting off. It's not leaking anywhere, so I'm a little confused what the issue might be. Ideas?
Check your main relay and FPR.
Nothing goes on that bar unless you someday decide to install A/C again, then you'll have a condenser there.
