I think the halos would look perfect with LEDS... if you made a new halo
from LEDs.
Make yourself an array of LEDs and wire up a set of them in a ring to come on for DRL (if you intend to keep DRL), wire the lower half of the array as low beam, and the entire array as high beam.
