Old 12-29-2009, 02:15 AM   #9 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by So_SiMpLe_ View Post
So the kill switch button in my car's case it cuts power for the Injection Pump when I press down the button right?
In your case cutting the fuel pump should work. Here are two threads to look into:
Kill switch how-to
Killing a diesel.
If you have a camshaft or crankshaft sensor, then cutting one of those may work (in my case - it doesn't ).
But It has to be a 2 button system so that the other button turns on the car right?
You can always use your key to turn the engine back on (or if you are still rolling, then bump starting would be better), but a start button is probably easier than a kill button, so you might as well do it.
