Old 12-29-2009, 05:31 PM   #18 (permalink)
mtgeekman
01 Insight - '01 Honda Insight DX
90 day: 67.82 mpg (US)
The reason the numbers between the insights FCD and the Scangauge don't match up is because of the lean burn.
The scan gauge doesn't monitor weather you are in lean burn or not. so it bases its calculations on a air/fuel ratio of 14.7:1 and assumes that this number does not change.
