Old 12-29-2009, 09:40 PM   #9 (permalink)
bondo
bondo's Avatar
Snow Visualization
Back in February of 2005 I photographed the way the snow had blown off the first aerocap I built on the way to work. It looks as if the air was turbulent in the central part of the roof and then became laminar as it moved rearward, blowing the snow away from the surface in two distinct wedge shaped areas.
The ridge of snow which built up along the edge of the cap is interesting. This first cap was not that effective because the roof was too flat and the angle of the roof was too severe causing separation.
I wish I could find the video of the flow visualization I did on the present design of the aerocap back in May of 2007 using yarn tufts. It showed good attached air all around the lid except for the rear corners. The two wind tunnel tests we have done showed the same when the smoke was applied.
Bondo
ID:	5236   Click image for larger version
