Originally Posted by Doni_99
Wheelskirt. Hm, I see that you have this kind of body parts on your Peugeot. How did you fixed them? I think, they are removable and not fixed with screwes. Do you have pictures of yours at short range?
Here are a few pictures from my
modding thread. Each is held on with 6 screws, which is overkill, 4 would be enough. Each skirt comes off in under 15 seconds. So far no problems
pulse & glide
What (/who) are they? The only thing that came to my mind is: Bonnie & Clyde
Pulse & glide is a driving style: instead of driving at a steady 60 km/h, you first accelerate (@80% max throttle) to 70km/h, then put the gear into neutral and coast. When your speed falls to 50km/h you put it in gear and accelerate to 70 again. The actual numbers vary depending on traffic. This usually works only below highway speeds - I believe there was a thread on this, here is what I found:
success : pulse and coast in neutral at mid speed (40-55 mph)
One of the variations of P&G is EOC-engine off coasting. Turn off the engine when the anticipated coast will be long, then bump start the engine (put in high gear and unpress the clutch). This method has safety (and legal) issues, so there are many things to consider before deciding to do it.
Check out this thread for more hypermiling tips:
100+ hypermiling / ecodriving tips & tactics
What matters is
where you're going, not
how fast.
